# Initial Setup Ready to get started with your new phone system? We'll walk you through everything you need — from signing up to making your first call. Don't worry, it's easier than you might think. ## Prerequisites {#prerequisites} :::info Prerequisites To use the phone system, you need: - A FlyNumber account - At least one FlyNumber configured to use the phone system - The cloud phone system enabled on your account — a flat **$14.95/month** charge, regardless of how many FlyNumbers you attach to it (see [Phone System Billing](/payments-billing/phone-system-billing) for the full pricing breakdown) ::: ## Enabling the phone system {#getting-the-phone-system} You can enable the cloud phone system two ways: 1. **With a new FlyNumber order** — at the routing step in the [Add FlyNumber](https://panel.flynumber.com/add-number/select-country) flow, select **Cloud Phone System**. The phone system is added to your account in the same checkout. 2. **Standalone** (if you already have one or more FlyNumbers) — open the [Phone System page](https://panel.flynumber.com/phone-system) and click **Add Phone System**. You'll pick the billing period and which existing FlyNumbers to route through it. Full walkthrough of both options: [Set to Phone System](/basic-settings/set-phone-system). :::note The phone system is a flat monthly fee that applies to your entire account ($14.95/mo). Adding more FlyNumbers to it doesn't change the price. ::: ## Accessing the phone system {#accessing-the-phone-system} Once the phone system is active on your account: 1. Sign in to the panel at [panel.flynumber.com](https://panel.flynumber.com) 2. Open [Phone System](https://panel.flynumber.com/phone-system) from the sidebar 3. Click **Open Phone System** to launch the phone system interface in a new tab :::note Authorization Error? If you see "You are not authorized!" when opening the phone system, your session has likely expired or there's a browser cache issue. Refresh the page and sign in again. If the problem persists, clear your browser cache and cookies. ::: ## Routing more numbers through the phone system {#adding-numbers-to-the-phone-system} **New numbers:** When you add a new FlyNumber while the phone system is already active: 1. Start the [Add FlyNumber](https://panel.flynumber.com/add-number/select-country) flow 2. Pick the country / area code / specific number 3. On the routing step, select **Cloud Phone System** 4. Complete checkout — the new number is automatically connected to the phone system --- **Existing numbers:** To attach an existing FlyNumber that's currently forwarding elsewhere: 1. Open the number from [My FlyNumbers](https://panel.flynumber.com/my-flynumbers) 2. On the **Call Handling** card, switch the routing option to **Cloud Phone System** 3. Save — the number appears under **Connected Numbers** on the Phone System page within a few seconds :::tip If you've routed a number to the phone system but don't see it under **Connected Numbers** after a minute or two, [contact support](https://www.flynumber.com/contact) and we'll take a look. ::: ## Where to next {#where-to-next} - **[The Phone System panel](./the-panel.md)** — tour of the workspace, modules, and call flows - **[Users](./main-menu/users.md)** — create app users and assign FlyNumbers to them - **[Modules overview](./modules/modules-overview.md)** — the building blocks for call flows - **[Example: Phone System App](./example-configurations/app-setup.md)** — full walkthrough from panel sign-in to app-on-your-phone - **[Phone System Billing](/payments-billing/phone-system-billing)** — pricing, billing periods, grace
