# Audio Playback The Audio Playback module lets you play pre-recorded messages or music to your callers. This is perfect for: - Welcome messages - After-hours announcements - Hold music - Custom greetings before connecting to a [Ring Group](./ring-group.md) - Error messages in your [IVR system](./voice-menu.md) ![Audio Playback module](/docs/phone-system-guide/modules/img/playback-module.png) ## Setting It Up {#setting-it-up} The Audio Playback module is straightforward to configure: 1. **Name**: Give your audio playback a descriptive name that helps identify its purpose, such as: - "Welcome Message" - "Holiday Hours" - "Support Queue Music" 2. **Audio File**: Select the audio file you want to play, or pick **Create Audio File** in the dropdown to generate one from typed text: - Manage your audio files in the Audio Files menu - Upload new files or record directly in the system - Supported formats: .mp3, .m4a, .wav, .flac, .ogg (up to 14 MB per file) ![Audio file management interface](/docs/phone-system-guide/modules/img/new-audio-file.png) :::tip[Audio File Management] You can: - Upload existing audio files - Record new messages directly - Create playlists for longer sequences - Preview files before using them ::: ## How It Works {#how-it-works} After playing the selected audio file, the module automatically forwards the call to the next connected module. This allows you to: 1. Play a greeting message 2. Then forward to a department 3. Or connect to another module for further call processing ## Practical Example {#practical-example} ![Audio Playback usage example](/docs/phone-system-guide/modules/img/playback-example.jpg) In this example: 1. A call comes in through a [phone number](./phone-number.md) 2. The Audio Playback module plays a welcome message 3. The call is then forwarded to a specific team member :::tip[Common Uses] - Welcome messages before connecting to an [IVR menu](./voice-menu.md) - Department-specific greetings before [ring groups](./ring-group.md) - After-hours announcements - Holiday or special event messages - Queue position announcements ::: :::note[Best Practices] - Keep messages clear and concise - Use professional voice recordings for business announcements - Test audio quality before deploying - Consider different language options if needed - Update seasonal messages regularly :::
