# Internal Number The Internal Number module enables extension-based dialing within your phone system. Think of it as creating shortcuts that let users call each other or reach specific features using simple extension numbers. ![Internal Number module appearance](/docs/phone-system-guide/modules/img/internal-number-module.jpg) ## Setting It Up {#setting-it-up} ![Internal Number module configuration interface](/docs/phone-system-guide/modules/img/internal-number-settings.png) When configuring an Internal Number module, you'll need to provide: 1. **Name**: A descriptive name for the extension, such as: - "Sales Conference Room" - "Support Team" - "Main Reception" 2. **Number**: The 1-4 digit extension that users will dial to reach this module. Pick it from the list of unused internal numbers you've added under **Numbers > Internal Numbers**. 3. **Is a Private Number**: This toggle belongs to a system-linking feature that is no longer available. Leave it off. :::note Extension numbers must be unique - you can't use the same extension number for multiple Internal Number modules. Manage your available extension numbers in the Internal Numbers tab of the Numbers menu. ::: ## Practical Example {#practical-example} Here's a common way to use the Internal Number module: ![Example of Internal Number module usage](/docs/phone-system-guide/modules/img/internal-number-example.jpg) In this example, an Internal Number module is connected to a conference room. Users with the phone system app or using a SIP account can dial the extension number to join the conference directly. :::tip[Common Uses] Internal Number modules are perfect for: - Creating quick-dial extensions for team members - Setting up easy access to conference rooms - Providing short numbers for frequently used features - Creating a simple internal directory system - Showing as the internal caller ID when a user calls another extension (chosen in the user's contact method settings) :::
