# The Panel Think of the panel as your phone system's control center - a visual workspace where you can drag, drop, and connect different pieces to build exactly what you need. Whether you're setting up a simple voicemail or creating a complex call center, everything happens right here in this intuitive interface. For simpler setups, you can just set up a [user](./main-menu/users) and [contact method](./main-menu/contact-methods/overview) from the main menu - no need to use modules. ![The main panel showing the workspace and menus](/docs/phone-system-guide/img/the-panel.png) :::note While the panel will load on a smartphone fine, we suggest using a desktop to configure your call logic. ::: ## Main Components {#main-components} | Component | Location | Purpose | |-----------|----------|---------| | **Workspace** | Center | The canvas where you build call flows by placing and connecting modules | | **Main Menu** | Left side (icon rail; click the arrow at the top to show labels) | Access system resources: users, contact methods, numbers, call logs, settings | | **Module Menu** | Right side | Drag building blocks (voicemail, menus, routing, etc.) onto the workspace | | **Cables** | Between modules | Connect modules to define how calls flow from one step to the next | | **Call Flows** | Main menu item (card grid); flow-name dropdown top left once a flow is open | Separate workspaces for managing different phone systems | | **Workspace Tabs** | Top bar | Organize a single call flow across multiple pages | | **Trash Bin** | Bottom right | Remove modules from the workspace | ## Workspace {#workspace} The workspace is the central canvas where you assemble your call flows. To build a flow: 1. Drag modules from the Module Menu onto the workspace 2. Position them where needed 3. Configure each module using the settings dialog that appears automatically 4. Connect modules using cables to create the call flow logic You can reposition modules at any time by dragging them to new locations. :::note All required fields in the module configuration must be completed before saving the module to the workspace. ::: ## Main Menu {#main-menu} The Main Menu provides access to all core functions and settings. By default it's collapsed to a rail of icons; click the arrow at the top of the rail to expand it and show the labels. ![Main menu showing different sections like Call Flows, Users, and Contact Methods](/docs/phone-system-guide/img/main-menu.png) - **Call Flows** - One card per call flow; open a card to build that flow on the workspace - **Users** - Manage user accounts and app devices in the phone system interface - **Contact Methods** - Configure app configurations, SIP accounts, PSTN forwarding, SIP forwarding, and email addresses - **Numbers** - Manage phone numbers and internal extensions - **Time Schedules** - Create working-hour schedules with exceptions and time zones - **Delivery Methods** - Configure delivery of voicemails and notifications via Email, Dropbox, FTP, SFTP, Google Drive, or OneDrive - **Audio Files** - Upload or record audio files and build playlists for greetings and hold music - **Call Logs** - Call charts, active calls, and detailed call records (CDRs); this item carries a *Deprecated* badge in the menu - **Call Analytics** - Call history, routing attempts, and call and user statistics - **Contacts** - Store contact details used across the phone system - **Settings** - General settings, domains, feature codes, cloud storage integrations, app activation settings, and call tags - **User Guide** - Help link at the bottom of the menu ## Module Menu {#module-menu} The Module Menu contains all available modules for building call flows: ![Module menu showing available modules like Phone Number, Voice Menu, etc](/docs/phone-system-guide/img/module-menu.png) Available modules include: - Phone Number - Internal Number - Ring Group - Voice Menu - Audio Playback - Conference - Voicemail - Fax - Call Recorder - Caller Router - Blocklist - Queue - Time Router - Notification - Forwarding The Module Menu can be minimized by clicking the X icon in the bottom right corner. Click the + icon to expand it again. ## Modules {#modules} Each module performs a specific function in your call flow. Modules connect to each other through sockets: | Socket | Position | Purpose | |--------|----------|---------| | **Input** | Left side | Receives calls from a previous module | | **Output** | Right side | Sends calls to the next module | Most modules have both sockets, but entry-point modules like [Phone Number](./modules/phone-number) and [Internal Number](./modules/internal-number) only have output sockets since they're where calls begin. When connecting modules, valid connection points highlight in blue. ### Module Configuration {#module-configuration} When you place a module on the workspace, a configuration dialog opens automatically. You must: 1. Complete all required fields 2. Click Save to add the module to your call flow ### Duplicating Modules {#duplicating-modules} To save time when creating similar configurations, you can duplicate existing modules: **MacOS:** Hold the Option key while dragging a module --- **Windows:** Hold the Ctrl key while dragging a module The new module will retain all settings from the original. Its name is the original's with a copy number added — for example, "Front Desk" becomes "Front Desk Copy 1". :::note Some modules, like Phone Number and Internal Number, cannot be duplicated since they require unique numbers ::: ### Selecting Multiple Modules {#selecting-multiple-modules} To select and move multiple modules: **MacOS:** - Hold Command to select individual modules - Hold Shift to select a connected group of modules --- **Windows:** - Hold Ctrl to select individual modules - Hold Shift to select a connected group of modules Selected modules will show a blue border and can be: - Moved together on the workspace - Moved to another tab - Deleted using the Trash Bin Use the same keys to drop a module from the selection. Clicking an empty area of the workspace deselects everything. ## Cables {#cables} Cables create logical connections between modules to define call flows. **Basic Connections:** To connect modules: 1. Hover over the right socket of the source module 2. Click and drag to create a cable 3. Connect it to the left socket of the destination module When you start dragging, valid connection points will highlight in blue. ![Connecting modules using cables](/docs/phone-system-guide/img/connect-cables.jpg) --- **Multiple Functions:** Some modules, like Voice Menu, can have multiple cables with different functions: - Extension number routing - Invalid extension handling - Timeout handling When connecting these cables, a configuration window appears to set the specific function. For example below, when adding modules after the voice menu, you'll be prompted for the digit(s) a user would need to press to get said module. To change the digit(s) later, click the number shown on the cable. ![Module with multiple exit points for different functions](/docs/phone-system-guide/img/multiple-exit.png) --- **Yes/No Logic:** Modules like Time Router and Caller Router have two output sockets: - Green socket (Yes): For successful condition matching - Red socket (No): For condition matching failures ![Module showing Yes/No logic sockets](/docs/phone-system-guide/img/yes-no-module.jpg) --- **Removing Cables:** To remove a connection: ![Deleting cable connections between modules](/docs/phone-system-guide/img/delete-cables.jpg) 1. Hover over the cable until the delete icon appears 2. Click the delete icon 3. Click **Delete anyway** in the confirmation dialog (it lists the two modules the cable joins) :::caution When a module has no outgoing connection (no cable from its right socket), calls will end after that module's function is complete ::: --- **Troubleshooting:** Common connection issues and solutions: - **Can't connect modules?** Make sure you're dragging from an output socket (right side) to an input socket (left side). Valid targets highlight in blue. - **Calls ending unexpectedly?** Check that all modules have outgoing cables where needed. A module without an outgoing cable will end the call after completing its function. - **Wrong destination?** Hover over the cable to see the delete icon, remove it, and create a new connection. ## Call Flows {#call-flows} [Call Flows](./main-menu/call-flows) are separate, independent phone system workspaces. Most users only need one (the default). You would create additional Call Flows if you manage completely separate phone systems from a single account—for example, different businesses. :::info[Call Flows vs Workspace Tabs] - **Call Flows** = Separate phone systems (different numbers, different users) - **Workspace Tabs** = Pages within a single Call Flow for visual organization (share the same numbers and users) If you just want to organize a complex call flow visually, use [workspace tabs](#workspace-tab-menu) instead of creating new Call Flows. ::: Choosing **Call Flows** in the main menu opens a card grid with one card per flow; each card shows how many users are assigned to it. Click a card to open that flow's workspace. ![Call Flows page showing one card per call flow with the add button in the bottom right](/docs/phone-system-guide/img/call-flow-screenshot.png) ### Creating a Call Flow {#creating-a-call-flow} To create a new Call Flow: 1. Open **Call Flows** from the main menu and click the + button in the bottom right of the card grid 2. Enter a name for the Call Flow 3. Add users who will be part of this Call Flow 4. Click Save ### Managing Call Flows {#managing-call-flows} You can quickly switch between Call Flows by clicking the Call Flow name at the top of the workspace. The same dropdown has a **Back to Call Flows** link that returns you to the card grid. To edit an existing Call Flow: 1. On the Call Flows page, click the Actions button on the flow's card 2. Select Edit 3. Make your changes 4. Click Save To delete a Call Flow: 1. On the Call Flows page, click the Actions button on the flow's card 2. Select Delete 3. Confirm the deletion :::warning Once deleted, a Call Flow cannot be restored. All associated data and settings will be permanently lost ::: ## Workspace Tab Menu {#workspace-tab-menu} Workspace tabs help organize complex call flows across multiple pages within a single Call Flow. This is useful when your routing logic has many branches that would clutter a single workspace view. **Managing Tabs:** Every Call Flow starts with a single tab named **Default**. You can rename it, but it can't be deleted until at least one other tab exists. To add a new tab: 1. Click the + icon in the top right of the Workspace Tab Menu 2. Enter a name for the new tab 3. Click Save To manage existing tabs: - Hover over a tab to see the settings icon - Click the settings icon to rename the tab - Use the delete button to remove a tab (requires at least one other tab) - Drag tabs horizontally to reorder them :::caution Deleting a tab will remove all modules and configurations on that workspace page. Use caution when deleting tabs ::: --- **Moving Modules:** You can move modules between different workspace tabs to organize your call flows better: ![Moving modules between workspace tabs](/docs/phone-system-guide/img/move-workspaces.gif) To move a module to a different tab: 1. Drag the module over the destination tab 2. Wait for the tab to activate (shown in blue) 3. Continue dragging the module down into the workspace 4. Release in the desired position :::important When moving a module that's connected to other modules, the connections will be maintained. A special icon will appear to indicate the connection spans across different tabs ::: --- **Connecting Across Tabs:** You can connect modules that are on different workspace tabs: ![Connecting modules between workspace tabs](/docs/phone-system-guide/img/connect-workspaces.gif) 1. Start dragging a cable from a module's output socket 2. Drag it over the destination tab 3. Wait for the tab to activate 4. Continue dragging to the target module's input socket 5. Release to create the connection The connection between modules on different tabs will be shown with a special icon that you can click to quickly navigate between the connected tabs. :::tip Instead of building everything on one tab and then moving modules around, it's often easier to: 1. Create all needed workspace tabs first 2. Build each section of your call flow on its appropriate tab 3. Connect the sections together using cross-tab cables ::: ## Search {#search} The search tool helps you find resources across your phone system: 1. Click the magnifying glass icon in the Workspace tab menu 2. Enter your search term 3. Results will be grouped by resource type For each search result, you can: - Use the locate icon (🔍) to find the item in the workspace - Use the settings icon (⚙️) to access the item's configuration ## Trash Bin {#trash-bin} The Trash Bin allows you to remove modules from the workspace: 1. Drag a module toward the + or X icon in the bottom right corner 2. The icon will change to a Trash Bin 3. Drop the module on the Trash Bin to delete it :::warning The Trash Bin does not have a recovery feature. Deleted items cannot be restored ::: You can also delete multiple selected modules by dragging them to the Trash Bin together ## Relations {#relations} The Relations feature provides a comprehensive view of how various components in your phone system are interconnected. This powerful tool helps you visualize all connections between numbers, users, modules, and contact methods. ![Relations dialog for an internal number with Inbound calls, Internal CLI, and Call Flows sections](/docs/phone-system-guide/img/relations-phone-number.png) ### Accessing Relations You can access Relations from multiple areas in the phone system: 1. **Numbers section**: Click the action menu (three dots) next to any phone number or internal number, then select "Relations" 2. **Contact Methods**: View relations for any contact method to see where it's used 3. **Modules**: Check which numbers and other components interact with specific modules ### Understanding the Relations View The Relations view organizes connections into logical categories: #### Inbound Calls This section shows which modules or contact methods will receive calls when this number is dialed: - Displays linked modules (like Support Internal Number) - Shows destination users or departments - Reveals the complete inbound call path #### Outbound CLI / Internal CLI CLI (Calling Line Identity) shows how this number is used for outbound caller identification: - User assignments - App configurations - SIP account settings - This helps identify which users or apps use this number as their caller ID #### Call Flows This section displays all call flows that include or reference this component: - Shows where the item is used in routing logic - Provides links to relevant call flows - May show "No relations" if not used in any call flows ### Benefits of Using Relations Relations offers several important advantages for phone system management: - **Troubleshooting**: Quickly diagnose call routing issues by seeing the complete path - **System Mapping**: Understand how different components connect together - **Change Management**: Assess the impact of changes before making them - **Dependency Tracking**: Identify which modules depend on specific numbers :::tip Always check Relations before removing or changing a component's configuration to understand the potential impact on your call routing. :::
