Messages and Call History
Each agent keeps its own messages and call history, on the Messages and Calls & limits tabs of its editor.
Messages​
When a Take a message rule runs, the message lands on the agent's Messages tab, newest first. The tab shows a count when there are messages.
Messages tab listing three messages, each with the caller's name, time, reason, the phone number they left, their caller ID and the number they called
Each message shows:
  • The caller's name as they gave it (or Unknown caller) and when they called.
  • The reason for the call, as the agent noted it.
  • The phone number the caller gave, the caller ID they called from, and which of your numbers they called.
The number the caller gives and their caller ID can differ; for example, someone calling from an office line may ask you to ring their mobile.
Delete a message​
Click Delete on a message, then Delete again to confirm. It disappears from the Messages tab only; the call stays in the agent's call history, message included.
Notifications​
Each new message also sends you a notification, shortly after the call ends:
  • Title: New message for '[agent name]'
  • Text: who it's from, the number they left, the reason, their caller ID, and the FlyNumber they called.
Clicking the notification in the panel opens the agent's Messages tab.
You also get a notification when a published version goes live.
Both arrive by email and in the panel's notification bell. To change that, open Notification Settings and use the Email and Panel toggles for the AI voice agents category.
When a rule sends the message elsewhere​
A Take a message rule can send its message to a message destination instead of the account email. That changes who gets the email for a new message:
The rule's Send toWho gets the email
Account email (the default)You, at your account's email address
An email destinationThat address, instead of yours. It's sent even if your Email toggle is off
A webhook destinationYou, as usual. The message is also posted to the webhook
In every case the message still appears on the Messages tab and you still get the panel notification. The Messages tab doesn't show where a message was sent.
Call history​
The Calls & limits tab lists the agent's Recent calls, 25 at a time, newest first. Use Older calls and Newer calls to page through.
Recent calls table with columns When, Caller, Number, Length, Result and Charge, and one call expanded to show its transcript and Tools used: end_call
ColumnShows
WhenDate and time of the call
CallerThe caller's number, or Hidden if they hid it
NumberWhich of your FlyNumbers they called
LengthLength of the AI conversation (minutes:seconds)
ResultWhat happened (see below)
ChargeThe AI charge for the call (see below)
Result​
ResultMeaning
AnsweredThe agent answered and the call ended without a transfer
Transfer requestedThe agent transferred the caller to one of your transfer targets. This confirms the handover, not that someone picked up at the target
Not answeredThe call reached the agent but ended before the agent answered
BlockedThe agent didn't take the call and the caller went to your fallback. The reason appears when you open the call (see below)
The reasons for Blocked are:
ReasonWhy
Monthly ceiling reachedYour AI spending hit the monthly ceiling
Too many calls at onceYour account already had 2 AI calls in progress
Balance too lowYour available balance couldn't cover the call
Hidden caller IDThe caller hid their number and Answer callers who hide their number is off
This number wasn't connected to the agentThe number wasn't set to this agent when the call arrived
Temporarily unavailableAny other reason the agent couldn't take the call
Charge​
ChargeMeaning
An amount, e.g. $0.23The final charge for the AI conversation. (estimated) after the amount means the exact usage wasn't available, so the charge was calculated from the best available record of the call
PendingThe call is in progress or its charge is still being settled
Under reviewThe charge is being checked by our team
No chargeNothing was charged for AI conversation (for example, a blocked call)
This column covers AI conversation time only. Your number's usual charges, such as per-minute charges on metered inbound numbers and transfers to phone numbers, are billed as usual. See Pricing.
Call details​
Click a call to expand it. Depending on the call, you'll see:
  • The message, if one was taken: Message from the caller's name, the number they gave, and the reason.
  • The transcript: the conversation as text, with the agent's lines on one side and the caller's on the other.
  • Tools used: the actions the agent took during the call, such as take_message, transfer_call or end_call.
  • For a blocked call, the reason it was blocked.
Calls aren't recorded as audio. The transcript is the written record of what was said.
How long call details are kept​
Call transcripts, taken messages and caller numbers are deleted 90 days after the call. The call itself stays in the list with its date, length, result and charge; its Caller column shows — and opening it shows Details for this call are no longer available. A taken message also disappears from the Messages tab, along with its notification in the panel. Emails you've already received aren't affected.
