Pricing, Limits and Settings
Pricingβ
$0.10 per minute of AI conversation, billed per second. No monthly fee for the agent; numbers, metered inbound, transfers and SMS are billed as usual.
In practice:
- You pay for the time the agent spends in conversation, to the second. A 2 minute 30 second conversation costs $0.25.
- Creating, saving and publishing agents is free. Publishing needs a balance of at least $10, but nothing is charged.
- Your FlyNumber's own charges don't change: the number's regular fee, per-minute charges on metered inbound and toll-free numbers, transfers to phone numbers at your normal forwarding rate, and SMS.
- AI conversation is paid from your prepaid balance. Each call's charge appears in the agent's call history.
Monthly ceilingβ
The monthly ceiling caps how much your agents can spend on AI conversation in a calendar month. It covers all your agents together: it's one amount for the whole account, so changing it on one agent's Calls & limits tab changes it for all of them.
It starts at $50 per month and can be set anywhere from $5 to $500.
To change it, open any agent's Calls & limits tab, type the amount next to Monthly ceiling, and click Save. An amount outside the range shows Enter an amount between $5.00 and $500.00.
When the ceiling is reached, callers go to your fallback until the next month starts.
A call in progress reserves part of your ceiling: it counts as a full 5-minute conversation ($0.50) until it ends and its real charge is known. A new call also needs that much room left under the ceiling to start. So a call can be sent to your fallback slightly before your spending reaches the ceiling.
Settingsβ
The Settings card on each agent's Calls & limits tab holds settings that apply immediately. They aren't part of a saved version, so there's no need to save or publish the agent after changing them.
| Setting | What it does | Default |
| Answer callers who hide their number | On: the agent answers callers who've hidden their caller ID. Off: those callers go to your fallback | On |
| Fallback phone number | Where callers go if the agent can't take the call. Enter it with its country code, for example +1 207 555 0182. Leave it empty to use voicemail or an unavailable message | Empty |
| Monthly ceiling | See Monthly ceiling. Shared by all your agents | $50 |
| Maximum call length | 5 minutes. Shown for reference; it can't be changed | β |
| Numbers | The numbers connected to this agent, or None yet. To connect one, see Connect a number | β |
Answer callers who hide their number and Fallback phone number are set per agent. The monthly ceiling is one setting for your whole account.
When calls go to your fallbackβ
The fallback takes calls the agent can't answer at all:
- The caller hid their number and Answer callers who hide their number is off.
- Your monthly ceiling has been reached.
- Your account already has 2 AI calls in progress.
- Your available balance is too low to cover the call.
- The agent is suspended, or can't take calls for another reason.
Those calls go to the Fallback phone number if you've set one; otherwise to voicemail or an unavailable message. They show as Blocked in the agent's call history, with the reason, and there's no AI charge for them.
The 5-minute limit works differently. When an AI conversation reaches 5 minutes, the call ends; it isn't passed to the fallback.
Limitsβ
| Limit | Value |
| Agents per account | 10 |
| AI calls in progress at once, per account | 2 |
| Length of an AI conversation | 5 minutes |
| Monthly ceiling | $5 to $500 (default $50), per account |
| Balance needed to publish | $10 |
| Rules per agent | 20 |
| Transfer targets per account | 20 |
| Transfer targets used by one agent | 10 |
| Message destinations per account | 20 |
| Saved versions per agent | 200 |
| Agent name | 80 characters |
| Who does the agent answer calls for? | 200 characters |
| How should the agent behave? | 600 characters |
| Opening line | 120 characters |
| Each rule's When⦠text | 200 characters |
| What should the agent know? | 4,000 characters |
| Text used (all of the agent's instructions together) | 6,000 (details) |
| Voices | Marin |
| Languages | Greeting in 16 languages; the agent speaks the language of your text, then the caller's (details) |
